NAXJA is having its 19th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
I used a "coolant Recovery" bottle from Pep Boys. Comes with fire-wall bracket and hose (fits where stock pressure bottle goes). Insure your radiator cap is intended for use with a recovery system. The proper cap has two internal valves; one lets coolant escape as it expands with heat, then the other lets coolant from the recovery bottle return to the radiator as it cools (causing a vacuum in the system).
