Converting a 2wd auto to 5spd 4wd in a 94 XJ
Rob Patterson
Colorado Springs
I did a search and couldn't find all the info I need. I have converted an auto 2wd to auto 4wd before with no problems. This time I'm also converting to a 5spd
Do I need a new ecu for the manual tranny? I'm thinking I can use a auto ecu because the tcu is seperate from the ecu, but there are different part #'s for each ecu. Does anyone know the difference? I know on mustangs the difference in auto and manual ecu's were the timing curve, idle control, and decel betwwen gears, but an auto ecu worked just fine with a 5spd.
I'm also converting a 2wd ax15 to 4wd because trying to find a tranny here in Germany is almost impossible. I already have a tailshaft housing and mainshaft cluster from a 4wd ax15, will this be enough?
Thanks,
I know on the early ECU's there is no appreciable difference between auto and stick. As the TCU controls the trans you shouldn't have any problems. I (and others)have used them interchangeably?
