I bought a Cherokee from a friend that bought LCA's and built the uppers. The thing is that when I took it all apart to put on My Cherokee I noticed that the upper arms are the same length as the lower arms.
Is there going to be any problems running like this. (he did for for a little while). I had it out once to try things out and it seemed ok. The problem I notice is the steering seems loose and part of it was hitting the steering dampener bolt.
Is this going to limit the flexing of the front or cause any other problems.
By the way this doesn't get driven on the street.
I have seen the charts that list how long they should be but for my 6 inches it is saying that the UCA only needs to be a 1/2 inch longer is that right?
Let me know what you guys think.
