Adjust the LCAs so that you maintain proper wheelbase length (101.4"). Then adjust the UCAs to get as close to the proper caster angle (generally ~ 5º to 8º) without causing damaging vibrations to the front drive shaft u-joint.
I was hesitant to post control arm lengths based on lift height simply because each Jeep is different. So as Bootlegger mentioned, just understand these lengths are guidelines, not the rule.
I am using RE adjustable uppers and lower CAs so easy adjustment. now to get atape out and start some measuring. Thanks guys you givien me a good baseline to start from
