COMPLETE: 3" lift and 30" tires/wheels
ArmyDad
Elk Grove, CA
Want to lift your XJ 3" and get some 30" tires already mounted? Here's the package I put together for my rig JUST before going taller and bigger.
Crown HD front coils springs (1" lift) NEW IN BOX
Rubicon Express coil spring spacers (1.75" lift) NEW IN BOX
KYB GR2 front shocks (less than 5000 miles)
TeraFlex Bar Pin Eliminators for front (accounts for 1" lift) NEW IN BOX
KYB Steering Stabilizer (less than 5000 miles)
Warrior sway bar disconnect (0-3" lift) NEW - but out of box
Crown HD rear leaf spring (1"+ lift) NEW - but out of box
Rear Spring Bushings - NEW (loose) for large and small ends
Takeoff: rear leaf spring - use main (without ends) under new main to give additional ~2" lift (total of 3")
KYB GR2 rear shocks (less than 5000 miles)
TeraFlex Bar Pin Eliminators for rear (accounts for 1" lift) NEW IN BOX
Rebuilt rear slip yoke driveshaft: new U-joints, balanced (less than 2000 miles)
For 3" lift on pre-96 XJ, the SYE is not necessary
4 - 30x9.5/15 tires (75% tread) mounted on XJ OEM aluminum wheels
1 - 30x9.5/15 full size spare (25% tread) on steel wheel
Package COMPLETE: $800. Location is Sacramento, CA. PM me with questions.
I'll post pics later if needed. You can look at my build thread to see the wheels and tires to some degree in the before pictures. Wheels are 18 years old but are otherwise straight without a lot of nicks and stuff. Tires do show some offroad use but, then, they've been offroad.
For now, I do not want to bust up this set. Lots of threads for getting up to 3" lift on a budget and it is ALL HERE including larger tires already mounted and balanced. I never needed to trim but you will want to space out the front stops so you do not rub the LCA.
If you get interested in parting it out, I'd be interested in the 30s, rear BPEs & disconnects
How much for all the lift parts?! I want the tires too but I can't pay to ship them.
Is this what you were wanting? Basically everything but the tires?
Let me know and I can get back to you right away ... I'm on BREAK now.
What brand/type of tire are they?
Yeah, that's what I want. I figure since I've supplied your build thread with entertainment I should get a discount. lol
I'm up in the air about how I want to lift this one... I may just hold off. I really want the tires more but shipping would be ridiculous.
