Hello ,
I've been plagued with this cold start issue and I've read countless threads on various forums regarding this issue to no avail.
Symptoms: After jeep sits overnight or an extended period of time, it will exhibit a really rough idle for about 5-10 seconds and smooth out on its own and drive perfect. It got worse today (steering wheel was shaking it was idling so rough) so I'm looking to finally fix it.
Knowns:
- Replaced injectors & heat wrapped all 6 of them to prevent common heat soak issue
- Fuel pump check valve is bad, been poor man's priming for the time being. This shouldn't cause a rough idle, just slow start.
Possible fixes:
- Front o2? Seems like I've read a few cases where the o2 sensor fixed it... but they were experiencing misfires on warm starts / cold starts, all the time.
- Clean IAC / TPS, doubtful it will fix it but I wont rule it out.
- Fuel filter?
Any other ideas / things I should check?
Thanks!
Knowns:
Possible fixes:
- Fuel filter?
Thanks!
