comanche rear lift
caspermj
I'm looking for only a couple inches of lift, and was wondering if anyone has put Dakota rear springs on (without the main leaf) to gain some lift. XJ's seem to get 3"+.
The MJ springs have more arch in stock trim than XJs so the same solution will give you less lift, but it will work. By trying different combinations of which leaves you use, you should be able to dial in anywhere between 2" and 4"
