blackd-out-chev
- Arizona
88 cherokee with the 4.0, doint 3 link front, 60/14b, 4 link rear. I'm wanting to run coilovers up front. 14" travel that are 36 extended/22 collapsed. Going for 5" uptravel, 9" droop; so at ride hieght they will require appx 27" of space and I only want around 5-6" lift. No problem cut the coil tower out and make a hoop right. Problem being....I run a snorkle for when we get in the deep water and would like to keep that functional. I'm using a modified factory airbox currently and it is definitely in the way. Has anyone else run into this issue and how should I fix it? I've searched here and been searching the net for some other kind of air cleaner that I could use/modify to run my snorkle but I'm not finding anything that looks promising. Any ideas? Trying to find or possibly build a cannister satyle filter possibly.
