coil spring spacer
truffle
Installing a 3" OME lift with coil springs and spacers that came in the kit, and was told to put the spacer in between the body and the coil isolator. My question is how does this (coil iso.) come off? It is attached to the bump snubber, but I can't see how it is attached to the body. I have a 97XJ Sport. Does this thing spin out on a bolt? The coil spacer can slide right up over the snubber and seat on the isolator, but I am pretty sure DPG told me spacer.....isolator......coil spring. Thanks, gonna join soon.
It may be stuck on there. You might have to pull it down. There is no mechanical connection though.
