$700later
- Jacksboro TN
well, i may have narrowed my problems down to the code 76. correct me if i'm wrong but code 76 is something like "fuel pump resistor bypass relay circuit" i've searched and found few results.
my jeep is a '94 4.0 5 speed, running extremly rich and won't run smooth enough to be driven. fuel pressure is 45-50.
i've replaced:
1.spark plug wires
2. spark plugs
3. o2 sensor
4. coil
5. dist. cap & rotor button
6. coil pickup
7. cps sensor
8. map sensor
9. ecu/computer
so whats next??? thanks! :laugh3:
i've replaced:
1.spark plug wires
2. spark plugs
3. o2 sensor
4. coil
6. coil pickup
7. cps sensor
8. map sensor
9. ecu/computer
