95cherjustin
- doylestown, pa
Help what the heck is that ENGINE LIGHT MEAN
Scanner says
27 Injector #4 or bank output stage does not respond properly?
1995 xj se 4.0 automatic 4X4
Injectors are bosch refurbished about 5,000 miles old or so from when i installed them last year
Checked fuel pressure and is perfect everyday with and without vacuum line connected
bad injector? bad injector o-ring seal? bad wiring harness? bad ecu board?
Scanner says
