- Santa Ana, CA
15 lb tank fill a 33x12.5r15 Tire from 8psi to 28psi about 25-30 times. Great tool for the trail because it fills tires much faster than an on board air compressor and you can run air tools if you break down on the trail.
great bang for your buck. Just needs to be filled and you’ll be ready to hit the trails and be able to air down and back up in a breeze.
SPECS:
CO2 aluminum 15 pound cylinder tank new. Was used once to test that it is indeed working perfectly. Sherwood CGA 320 valve plus a black carry handle. Tank is made in USA. High quality 1/4"x 25ft recoil poly air hose with swivel ends and bend restrictor fittings. Plus Inflation gun, with locking chuck and 2-inch gauge, ¼” NPT and flexible hose. Topped off with a Gentec flow regulator.
SPECS:
