- Maurertown,Va.
My nephew has a 95 YJ 2.5,5spd .130,000 miles
Problem is when shifting ,after 4 or 5 shifts the tranny will scrape when shifting.Clutch MC has been replaced as well as the line to the throw-out bearing.System has been bled several times.
After sitting for several days it will shift fine for 4 or 5 shifts and then start the grinding.
When shifting delibertly(sp) slow, no grinding.Shifting at a normal speed it will grind.I guess that the throw out bearing is sucking air into the system,but that is only a GUESS.
Anyone have a solid answer?
Thanks,
Wayne
Thanks,
Wayne
