48MJ
- corvallis,oregon 97330
I installed a different ax5 in a 86 mj with a little different looking bell housing.Everything that had to line up looked right.But after it was together the clutch wouldn't release.It was bled right with new master and slave cylinders.Finally we took the spacer between the slave and bell housing out and put the slave back on closer to the bell housing.Now the clutch works with about 1.25 inchs removed fom the spacer.Anyone ever have a problem with this before I still don't know what happened. THANK YOU
