Brooks_McClintock
- North Dakota
So this has happened since a recent install of my clutch, I did not install it, my friend (a backyard mechanic) did and he is a pretty knowledgeable mechanic.
So a few days after he installed the clutch (it was a rhino series) something in the clutch system started to squeak. The squeak is a rotational squeak, it speeds up when the jeep accelerates and slows down when I let the throttle is let off. The clutch doesn't make a noise when the pedal is pressed down, and sometimes when it's in a higher gear like 3rd or 4th and never 5th is doesn't make noise.
My bud said it might be a hydraulic problem. Something with the cylinders. I'm clueless when it comes to clutching so any help would be great.
