stroked88
- Carlsbad NM
has anyone else had a similar problem? ive searched, but to no avail. I have an 88 that i have swapped in an ax15 from wrangler with internal slave. my exact problem is that after i have been driving in town for a while, when i stop with the transmission in neutral, and push the clutch in, i cannot get the transmission into gear. there is no grinding, but it feels like theres something there just stopping the shifter. If i turn the jeep off and put it in gear, it goes fine. I can start it in gear, or stop in gear with the clutch in and it doesnt try to jerk or lurch. this is whats got me confused. it shifts fine once im going, and if i put it in gear rolling it will go fine. but if im at a dead stop, it wont? when cold everything works well. all the hydraulic parts are for the 1988 and new. new centerforce clutch and pressure plate, rebuilt the ax15, and resurfaced the flywheel. did have a diff clutch in after rebuild and it worked fine but was replaced because it got noisy.
