MudfrogK5
- Roanoke VA
Ok on my 90 4.0 I converted it to an open style using a filler neck and 1 qt overflow bottle which I was told is plenty big. I guess the bottle is just defective but I wanted to ensure I did not do something wrong or choose a wrong bottle.
The overflow bottle is leaking like crazy, steam will come from the top and bracket area and this morning it was pouring coolant out of the ball valve at the bottom even though it's closed.
This is the one I went with:
http://www.jegs.com/i/JEGS/555/511010/10002/-1
The radiator cap I chose is a Moroso 12-16lbs cap.
Should I choose a different overflow bottle? Need to fix this ASAP.
