Cleaning out the Garage ...
ArmyDad
Elk Grove, CA
Cleaning out the garage so the winter work can begin.
Located in Elk Grove (12 miles south of Sacramento on Hwy 99)
$75 … C8.25 axle (3.55). New brakes and all brake parts. New YJ E-brake cables.
$100 … OEM roof rack w/4 crossbars)
$50 … Front receiver hitch (Draw-Tite 65009)
$50 … Rear receiver hitch (Draw-Tite 75054)
$25 … v8ZJ drag link and tie rod (w/ trail spares)
$10 … v8ZJ pitman arm (XJ+1")
$10 … (2) OEM-type UCAs (<5000 miles)
$45 … Rock Krawler swaybar disconnect (4.5" to 8" lift) NIB
$45 … OEM front sway bar w/ urethane bushings and swaybar disconnect
$50 … (2) Front coil springs (XJ+1") (UNUSED)
Coil spring spacers:
$25 … (2) 1-3/4" urethane (UNUSED)
$10 … (2) 3/4" rubber (UNUSED)
$25 … Air filter box (upper) w/ filter
$20 … (2) Garmin receiver license plate brackets
$15 … (2) OEM-type rear spring shackles
$10 … NP231 tail housing w/ bolts
FREE … OEM rear Bumper
FREE … XJ power steering spacer (aluminum)
Checking in daily if you have any questions.
I want the Front receiver hitch (Draw-Tite 65009) if it's in good condition.
I have a bone-stock 2001 XJ 4.0L 4x4 with auto transmission. If the UCAs fit I want them too.
If the C 8.25 fits I am interested, but haven't figured out how to carry it.
I sent you a PM -- please call that number tonight or tomorrow before I hit the road.
Thanks!
UPDATED 12/14/12 ...
UPDATED 12/17/12 ...
I was asked to supply some pics of the sway bar with disconnect ...
This was taken off when the lift went from 5" to 7".
Swaybar diameter is 29mm ... that is the largest of the XJ factory bars if I'm not mistaken.
Tom
UPDATED 12/27/12 ... Some items have had prices dropped.
$50 … C8.25 axle (3.55). New brakes and all brake parts. New YJ E-brake cables
$50 … OEM roof rack w/4 crossbars)
$35 … Rear receiver hitch (Draw-Tite 75054)
$15 … v8ZJ drag link and tie rod (w/ trail spares)
$35 … OEM front sway bar w/ urethane bushings and swaybar disconnect
$30 … (2) Front coil springs (XJ+1") (UNUSED)
$10 … (2) 3/4" rubber isolators (OEM-UNUSED)
$10 … (2) Garmin receiver license plate brackets
$10 … (2) OEM-type rear spring shackles
UPDATED 12/28/12 ... Some items have had prices dropped.
UPDATED 1/3/12 ... Some items have had prices dropped.
UPDATED 1/4/12
Thanks!
Tom
UPDATED 1/12/13
Thanks!
Tom
