Jay Welch
- Abington, Massachusetts
FOR SALE: 1989 Jeep Cherokee Pioneer, 4 Door, 4.0, 4WD - Price $2000 Firm
Completely stock, has not been hacked and never off-roaded in the 5 years that I've owned it. No mud or sand underneath so I doubt it has been off-roaded by previous owner(s) either. I've only used the 4WD in snow. Doesn't burn or leak oil. Generally gets 18 to 21 MPG but have gotten as high as 23 MPG. Everything works except the AC (see below). Has been maintained by me for past 5 years. Have all maintenance records and most receipts from that timeframe. Drives well and is very strong. There are a lot of old pigs out there still running around but this one is clean. Differentials: 3.55:1, 30 Front, 35 Rear.
• 164,000 miles - only 38,000 of those since fall of 1999. Low miles considering year.
• 4.0 has good oil pressure and cooling, always starts - doesn't burn oil and no raps, taps or slaps.
• AW4 automatic shifts great, never a problem, has Power/Comfort switch
• NP231 Command-Trac transfer case works well and linkage has been kept lubricated.
• Exterior is solid black with 2 inch black/chrome side moldings and gloss black fender flares. Door hinges are fine and have never required repair.
• Interior is gray cloth and trim with charcoal colored dashboard. Carpet, seats and cargo area is quite clean with no tears. Dashboard etc has no cracks.
• Air conditioning needs a recharge. All components work but it got weak and I never recharged with R12 or retrofitted for 134-A. Jumping refrigerant pressure switch will kick in and turn compressor freely.
• All power windows and power door locks work.
• Tilt wheel, power steering, power brakes (non-ABS), clock, rear defrost, rear wiper/washer, factory roof rack, set up for din style radio...you supply.
• BF Goodrich All-Terrian T/A white lettered P235/75-R15 tires mounted on stock 10 spoke alloy wheels with all original hardware. Tread is getting to end but should pass inspection as it did 2500 miles ago. Two spare white lettered 235/75-R15 BFG Trail T/As with excellent tread included.
• Full tank of gas
New parts - most recent listed first
• Pro Comp ES3000 shocks in front and rear, bar pin eliminators used in front
• Door lock circuit upgraded with Greg Smith mod
• Water pump (new not rebuild)
• Serpentine belt
• Battery
• Muffler and tailpipe (Walker lifetime brand)
• Front brake rotors, calipers, pads, flex hoses
• Right front axle U-Joint
• Rear brake shoes, cylinders, hardware kit, hard lines
• Ignition (Key) switch
• Cooling bottle and cap
• Heater hoses and clamps
• Radiator and thermostat
Not much really wrong with it but......
• I never liked the rear brakes. I suspect the proportioning valve. A new $50 Wilwood adjustable proportioning valve is included with sale. Just needs to be plumbed into rear brake circuit.
• Headliner is starting to droop.
• Interior is very clean but seats could use a mild shampooing for normal dirt...no grease stains.
• Front suspension creaks occasionally, would probably benefit from new front suspension bushings.
Please reply via email at [email protected]
Digital pictures available @ http://community.webshots.com/scripts/controlPanel.fcgi
• Full tank of gas
• Serpentine belt
• Battery
