Clayton Off Road
Clayton Off Road
- East Haven CT
Our Jeep Cherokee XJ 1/4 flat skid plate was designed as an addition to our Clayton Off Road Mfg. rear coil conversion lift kits. This skid plate is CNC laser cut, and CNC bent for superior accuracy, fit, and strength.
It bolts onto the front 3 piece cross member, and requires a custom rear mount to be welded into the unibody frame rails.
This rear mount is part of the coil conversion kit and necessary to install this skid plate.
Kits comes with 1/4 flat skid, and hardware ONLY. This kit is NOT intended to be used on a stock setup.
For more information, or to place an order, check them out here.
Alex
Marketing Director
Clayton Off Road
Alex
Marketing Director
Clayton Off Road
