cherokee part out
Keith M. Anderson
Woodbridge, Va.
C:\Users\kma\Pictures\2012-06-16 1988 cherokee
Interior gray, body and frame is in very good condition, completely stripped out interior, elec. doors, rear hatch all work as they should. chrome bumpers w/ stock tire carrier, chrome roof rack w two bars present. Would need to replace rubber strips under roof rack rails. 5 jeep alloy wheels in good shape. one is scared but other four are in great condition. Tires not worth anything.
runs but rough. no smoke. Body and frame in fantastic condition. Interior is completly stripped out of it.
Body/frame w engine, AW4 transmission and NP242 transfer case no axles no front suspension, rear springs are still on. $400
5 jeep 15 x7 alloys. typical of shown,- $50
goodyear wrangler tires 30 x 9.5 approx 50% tread $100
4 ea. 10 x 15" aluminum wheels (no center cap, round holes) 5 x 5 have 33 x 12.50 all terrains mounted on them, tread ok dry rot is the problem $100
wheel adapters 5 on 5 to 5 on 4.5 (can mount 5 x 5 pattern on 5 x 4.5 hubs) $100
prothane master xj bushing kit still in packageing SOLD
shocks for 3" lift (rancho 5000) $50
XJ rear spring pack with long and short leaf added (netted 4.5" lift, very stiff pack) $100
track bar and frame bracket $25 each (2 to choose from)
front sway bar and brackets $20 (2 to choose from)
Rear sway bar and brackets $20
upper control arms $50
lower control arms $50
stock steering setup $50 two to choose from TREs are fine
heavy duty steering setup brand new never installed has TREs for grand cherokee (I believe this is the Currie Currectlink) sold
Front buckets, recline ok shape $25 each
Rear Seat both pieces, latches and pivots all work fine (2 to chose from) ok shape $50 each
chrome luggage rack, two bars there, in good shape - $50
factory spare tire carrier in fantastic condition. Rear bumper all the brackets and hardware for spare tire carrier already removed. Bumper is chrome and in good condition, both endcaps included -$150
Front bumper chrome with end caps good condition -$25
All interior pieces and moldings are removed from vehicle in great shape. Color is gray. Let me know what you need. Rear seat has chrome strips on back, all there, missing one end cap I believe. Let me know what you need.-doors are electric window and lock all work as they are supposed, door cover in fantastic shape. Rear hatch all locks, defrost and wiper work as they should wiper arm is missing.
front glass is cracked. All other glass is fine.
Engine is 4.0 over 200k runs rough, (FUEL INJECTION) but no smoking, still pulls strong- $200
Has the AW-4 transmission and NP-242 full time 4x4 transfer case, (2 hi, 4 hi full time, 4 hi part time, and 4 lo) $200 each/ $300 together
D-30 front axle (non disconnect) 3.55 gearing, excellent condition never offroaded, heavy duty cover $200
D-35 rear axle 3.55 gearing, excellent condition never offroaded, heavy duty cover SOLD
chrysler 8.25 rear axle 3.07 gearing, good condition $150
chrysler 8.25 rear axle, 3.55 gearing, one side brake mounting plate is bent $100
Rear Drive shaft from 94 XJ w manual transmission. Rebuilt with greaseable heavy duty ujoints and balanced by spicer dealer Northeastern supply in Springfield $100
stock front springs and bump stops (very new) tag still on one of springs $75
Rear springs in good condition, no sag to vehicle $75
driver door/passenger door $50 each
rear hatch $75
2" Reciever hitch $50
Stock flares in good shape/ someone painted at some point $25 for set of 4 (2 door)
If you are looking for a good start point for rail buggy here it is. If interested in whole vehicle or parts Please call Keith at 703-657-9309. CASH AND CARRY . . . NO EMAILS . . . LOCAL PICK UP . . . I AM IN LAPLATA,
I can email detailed picture of anything u are interested in. Only thing left inthe vehicle is engine, trans, transfer case everything else already pulled
1988 cherokee Laredo Edition
Console is in great condition, no rips, hinges there and work no screws stripped. I will not piece out console. Will come with Gray base piece, black insert, metal support bracket for inside console, console lid w hinges (gray), AC duct .
There is no value to console with out the lid so I will not seperate console pieces. I will ship just the lid if that is what you want but same price. If interested send me a text, w name and address and I will box it up and find out shipping cost for you. I do have a paypal account.
$50 plus shipping.
I have 94 Cherokee that interior will be removed from also. Gray in color. Only interior piece I will keep is headliner and trim pieces at top of rear window. Rear seat latches and pivots in working condition.
I only have chrysler 8.25 w 3.07 gearing
and C8.25 w 3.55 gearing left
3.55 geared axle has broken shoke mount on one side, and brake backing plate is bent. Axle straight. good start for build $50
3.07 axle good shape, brakes in working condition $100
muddbank - $50 + shipping if I pull it apart.
If your local, come pull it apart< I'll let you have the gear set for your troubles, I keep the shafts and housing.
Stokee95 - my 94 radio and antenna will be staying in current build.
back seat, carpet, any lower interior trim pieces and even console I will sell out of 94.
The 88 interior is the same as the 94. 94 rear lower trim good condition, 88 is fair
88 cord and chrome antenna $10 + shipping
Glyphic - rear hatch ofmy 94 is black, all manual, with wiper motor attached no wiper arm, rear glass replaced w no defrost-door is wired for defrost though. I just didn't need defrost.
88 Hatch is same as 94 as far as shape and mounting. faded blue, elec. looks, elec wiper motor attached, defrost glass intact.
BOTH HATCHES IN GREAT PHYSICAL SHAPE. WILL COME WITH HINGES, BOLTS, WIRING INTACT TO MODULAR PLUG. $100 EA.
WILL NOT SHIP THIS ITEM LOCAL PICKUP ONLY. DELIVERY WITH
IN 50 MILE RADIUS OF FAIRFAX, VA. POSSIBLE WITH A LITTLE CO-ORDINATION
I can send very detailed picture of any piece of interest from either 88 or 94 cherokee. text request OR EMAIL ADDRESS, to Keith at 703-657-9309. Include piece interested in and zip code if you will need shipped.
I CAN NOT FIGURE OUT HOW TO POST PICTURES HERE!
I am not trying to put my boy thru college here. Just trying to get money back on parts vehicle and add funds to build of 94 of course. Helping out a fellow jeeper is added bonus - Send offer. Wife not going to tolerate this thing sitting in yard forever! : )
$50 plus shipping.
No thanks. Haha
UPDATED PARTS LIST
goodyear wrangler tires 30 x 9.5 approx 50% tread (4 total) $100
wheel adapters 4.5 x 5 $100
Rusty's 1.75" coil spacers $50
stock front springs (2 pair) $75 pr.
rear hatch (1 blue/ 1 black $75
If you are looking for a good start point for offroad rig here it is. If interested in whole vehicle or parts Please call Keith at 703-657-9309. CASH AND CARRY . . . NO EMAILS . . . LOCAL PICK UP . . . I AM IN LAPLATA,
Keith-
Is the Renix computer still good? If so how much?
Thanks
Eric
Engine started when I bought but running/idling very rough. Drove car up onto trailer. I simply wanted the axles. Found several vacuum lines attached to injection system disconnected. Also found house from air box to throttlebody was crushed allowing air to bypass filter. Plus another air hose, to exhaust header, was not intact. So any and all of these things could have produced rough running. Engine will still start as it sits. Come on by and take a look. If anything you can use make an offer.
thanks,
Keith
703-657-9309
