MXJ
- Moline/Peoria, IL
I'm getting out of the jeepin business to pursue other ventures, maybe something fun for a change. I will have all the pictures by this weekend since its 100 miles away right now. I have no stock interior or exterior sheetmetal. That means, doors, hatch, dash pieces, glass, trim, carpet, nothing. Located in Moline, IL. Local pickup perfered with cash. Otherwise I accept PayPal and USPS money orders. Shipping will be on your dime.
Engine:
4.9L stroker built by Clifford Performance in '95, rebuilt by me last summer. 0 miles/.5 hours. Power numbers are unknown; had it running all of 30 minutes.
Video of it running after break-in: http://www.youtube.com/watch?v=c2ucf_-qJFs
.060 over
Custom offset ground 258 crank
Clifford 290 dur. cam and solid lifters
10:1 comp
Arias pistons
Eagle Chevy 327 rods
Custom head work
CRT HEI distributor and 8mm wires
Champion Gold Plugs
Clifford timing set
Balanced to 7000 rpm
Clifford 4bbl intake
All ARP hardware
Clifford Roller Rockers
Have receipts and original paper work.
$3000
Trans:
'98 AX-15 unknown mileage. I went through it and replaced a couple pieces (5th gear set) and checked it all out. Turns smoothly through all gears.
$200
Brand new RinoPak clutch for the Ax-15, 0 miles.
$100
Transfercase:
NV231 w/ SYE kit, 23 spline input.
$225
Front Axle:
HP Dana 30, 4.56 gears, stock shafts, open.
One bad caliper, I believe.
$300
Rear Axle:
Chrysler 8.25, 4.56 gears, Detroit locker, stock shafts.
$400
Lift:
Rubicon Express 4.5" kit w/ full leafs and control arm drop brackets. The kit is in good shape, just lacking a little cosmetically after 5 years. Everything is good condition, including shocks, but the leaf packs sag a little.
$600
Tires and Wheels:
(4) 34x10.50r15 LTB's, good tread, 85% or more, have some cracks (not deep) in the side walls.
$300
(4) 15x8 steelies, chrome finish with black paint flaking off.
$75
Skids:
Tomken gas tank skid, powdercoat almost completely gone.
$100 Pending sale.
Tomken center/transfercase skid, good condition, just some scrapes.
$50
Tomken rear bumper, missing some pieces that tie it into the "frame". Powdercoat is in sad condition.
$75
Misc: Make on offer.
Stock front driveshaft (auto)
Steering column
Gas, brake, clutch pedals
Stock Electric fan
Brake booster/master cyl.
Clutch slave/master cyl. setup. Brand new.
Big Daddy Offroad upgraded tie rod.
$60
C-Rok inner and outer steering reinforcement plates.
$40
Stock steering box, leaks from the sector shaft.
(2) stock hoods, black.
I am willing to sell the "shell" after all parts are removed with a clean title. It has a Essentially offroad cage (modified a bit) and some front tube work that ties into C4x4 Fabrication front winch bumper. If there is no interest it is going to the scrap yard.
Stay tuned, my CJ-10a may be next.
Engine:
.060 over
10:1 comp
Arias pistons
Custom head work
Champion Gold Plugs
Clifford timing set
All ARP hardware
$3000
Trans:
$200
$100
Transfercase:
$225
Front Axle:
$300
Rear Axle:
$400
Lift:
$600
Tires and Wheels:
$300
$75
Skids:
$100 Pending sale.
$50
$75
Steering column
Stock Electric fan
$60
$40
