NCSU90XJ
- Wilmington, NC
I plan on changing out both driver and passenger side axle u-joints on my 90XJ this weekend. The shop I purchased the 5-260X Spicer joints from mentioned placing the vehicle in 4WD prior to starting the work so that when pulling the passenger side axle, the vacuum disco collar will not slide off and screw up the re-assembly. So my question is, is this correct? If the collar resides (when axle is disconnected) on the half shaft (axle between pumpkin and vacuum disconnect), then I should be OK. On the other hand, if it resides on the passenger side axle when disconnected, then I could see this being a problem when pulling this axle as it could slide off. Thanks for any feedback!
