alright i swapped my engine and trans out 3 months ago and after the swap had a cel for the nss. the jeep that the trans came out of never had a light on and yes the bulb is functional. is it possible that the linkage for the shifter is not adjusted right?
jeep starts up in park and neutral, will not start in gear, and runs and shifts just fine. i unfortunately have to get my emissions done in 1 month.
i cant remember the codes but will pull them tmmrw.
97 on the engine, 2000 on the trans, the speed sensor, harness, and magnet have been changed on that side. the nss is the same as my 97.
here are the codes
po 1694 no ccd message from pcm
po705 trans range circuit PRNDL input
p1899 park neautral switch stuck in park or in gear.
thanks for the help
today i checked the connection at the pcm, found to be good. checked the nss harness at firewall found ok. found the reverse light to work.
im curious if the adjustment with the linkage could be causing this.
alright replaced the switch and still have the same codes . i cleared them and drove around and they came back active.
went to firestone today and they hooked their scanner to it and only p705 and p1899 were active. they checked the nss, checked the connection at the nss harness, cleaned the connector, made sure that the pins were good. we replaced the battery due to low voltage. and i still have codes p705,and p1899.
they think that its inside the transmission on the shift solenoid side, but that does not make any sense as all the codes are related to a nss which is a different harness.
here are the codes
thanks for the help
