sjx40250
- Alexandria VA
I would have asked this question in my other thread but I think it is dormant.
I have freshly installed a lift which was suppose to be 3.5 and ended up at 4. I assume it will settle down a bit.
The caster is off by 4 degrees. I have both upper and lower adjustable control arms that are measured at 15 upper and 16.5 lower.
Two questions.
1. Can I adjust by controlling the torque on the axle from the springs to loosen the uppers? I would do this with a jack under the spring mounts.
2. Which should I adjust, the uppers or the lowers? I am thinking the uppers because they are already at the minimum length and I would need to lengthen them to reduce the caster angle.
Two questions.
