- Hartsville, South Carolina
This is what I know of right now. I think I will find more when I start looking in the daylight. Front header on passenger side is crushed. Same side inner fender is wrinkled. Passenger door is fubar'd! Passenger rock rail is missing on grade 8 bolt and the other three are stretched. Rock rail moves up and down about 4 inches. rocker under is recessed. Passenger rear glass is scratched? How do you drag glass along a rock and just scratch it? both rear taillight mounting positions are recessed. Driver D pillar is crushed. Rear hatch and glass it destroyed. Driver door does not shut all the way. B pillars are cracking really bad. Door striker is loose from cracks in the metal it is mounting to. Driver side rear glass is shattered. There are dents everywhere. Track bar bracket is half off. The lower bolts were ripped out and the frame there is bent bad. It was an awesome time!!!! :conceited
