Jarvis_Pants
- Doha Qatar
Ok so i have a 97 XJ automatic which has sum seriouse engine problems the mechanic says it needs to be torn all the way down to get to the problem. As i have sum spare time i thought i would give it a go. So with Haynes manual and tools at the ready i started tearing into the engine.
So heres where i hit a snag. Trying to remove the fuel rail the haynes manual says to unbolt from the heat sheild and rock gentle back and forth till it comes free. Well i started with gently then got a little pissed so started rocking quite forcefully then tryed prying it off still nothing. The manual shows pictures for a 96 so i dunno if thats the problem. Any help would be great thanks.
Secondly i need to disconnect the fuel rail from the fuel line in the manual it talks about quick disconnects with tabs.... well this connection dosent have tabs its just a metal connector (if no one replys before i get home i will get pictures.) There seems to be sum play but i cant force the two apart. Any help would be a apreciated.
