XJ 4-play
- Albuquerque, New Mexico
I've read all the threads concerning rear sway bars and towing. Aside from lost flexibility is there anything that would cause problems running the rear swaybar. (clearance problems or bad angles)
I ask because most people just eliminate them after the lift. But towing regularly (less than 2000#'s) in high winds I would like the extra stability.
Anyone ever work up a Rear Sway bar Disconnect.
I'm thinking that only 4 bolts for the hangers and two little bolts would allow me to remove the sway bar in around 20 minutes.
It would be nice to two my toys to the lake then play around in the hills and sand while im there.
