themangeraaad
- Halifax, MA
This is a non-Jeep vehicle so I figured I would post here
Can a warped brake rotor cause a slight vib in the steering wheel (and maybe in the seat a bit as well)?
Bit of background: My '08 altima (currently at 42k miles) had warped rotor(s) earlier this year; I brought it in under warranty and the dealership turned them. Problem fixed... for a while. The rotors warped again maybe a month later (and no, I wasn't driving/braking aggressively).. I have been dealing with a slight rotor warp for a few months now. I just never have the time to get into the dealership and bitch at them for s****y rotors and tell them I do not want them turned again, and that I want replacements since turning didn't do anything the first time around.
I just got the tires replaced maybe a month ago and ever since they were replaced is when I have felt like the tires were out of balance, I have a bit of a vib in the steering that is speed dependent. There may have been a very slight bit of a vib before tires were replaced, though not as much as now.
I had the tires replaced at a local NTB, and 2 weeks later brought it into a different NTB location to get them re-balanced (incase the first shop f***ed up). Even after a 2nd balance there is still a bit of a vib.
The mech at the 2nd shop said that he found one [rear] tire slightly out of balance, but nothing that should be causing vibrations. He re-balanced it and the vibs were lessened... just not gone. He also mentioned that if the problems continued it may be a bad tire that needs replacement (wouldn't the balance tell him if the tire was bad?). In addition he said it may take a bit of driving for new tires to break in, I now have approx 3k miles on the tires and no improvement.
I am going to go back to NTB and seeing what they can do for me, but before I keep chasing them I figured it was worth asking if a warped rotor could be part or all of my issue. I originally figured that the rotational mass of the rotor compared to the tire was minimal so it isn't likely a small warping will cause much of an issue.. but I want to be sure my thought process isn't incorrect.
Thanks,
-Scott
Thanks,
-Scott
