xj-boonie
- Hastings, MN
I just got my alignment done also (haven't picked up the XJ yet) after putting new ORO U-turn steering on it and a 97 XJ front axle. They said that I've got 1 degree too much camber on the left side (not sure if it's positive or negative) and that replacing the upper left ball joint with an off-set one would fix it, but the current ball joint is good. Also, my left side wheel bearing is a little loose.
I'll post up the specs when I pick it up this afternoon.
Just wondering if I can live with the camber or should replace the ball joint? I'm more worried about the wheel bearing (and the bad u-joint I've got on the passenger side...).
Thanks,
Mike
Thanks,
Mike
