Khary23
- Brooklyn, NY and Worcester, MA
I got an alignment today and the camber on the drivers side is -1.1* my FSM has the preferred camber as -.25* with a range of -.75* to .5*. I know that I need an upper ball joint on that side so my question is will a bad ball joint cause the camber be so far out of wack? Thanks!
1999 Cherokee
4" OME lift
31" tire
V8 ZJ tie rod
Iron man 4x4 adjustable track bar and adj control arms
New ball joints and u-joints passenger side
New moog TRE on the draglink
1999 Cherokee
4" OME lift
31" tire
V8 ZJ tie rod
