Calling all Woofer/Audio Gurus.
Seiler
Aurora, Colorado
Ok. Here's the plan.
Building a new woofer box. Holding two 12's.
Specs:
Subwoofers:
Power Acoustik FUBR-12
700 watts RMS
Dual 2 ohm voice coil
1800 watts max
2-Channel Amp:
Power Acoustik LT1920/2
Bridged RMS Power @ 4 Ohms: 880W x 1
1920 Max Watts
K. Old box broke...
Building new box...
Woofer Pictures...
Amp....
Now, on to the question. How the heck am I supposed to wire these? I use to have the positive and negative going to one terminal on the woofer itself. However, aren't I supposed to incorporate the dual voice coils and use both + , - terminals?
I went onto Rockford Fosgate and found a Woofer Wiring Wizard...
LINK:http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
and came up with these results:
OR
Is that correct? I'm a little weary about wiring + and - together. Then again, I don't have any knowledge in this field.
Help? :D
-Scott
after you wire it up hit it with an ohm meter and make sure you're pulling 2 ohms resistance. your speakers say dual 2 ohm so hook em up like this
just make sure your amp can handle a 2 ohm load or you'll burn it up pretty quick. it should say what load it can handle somewhere near where you hook up the speakers, or on a sticker on th eunderside next to the model/serial number
hth
-mike
dont forget to use screws for your box. :) so it wont split apart again
i just read your post again...
Subwoofers:
700 watts RMS
1800 watts max
2-Channel Amp:
1920 Max Watts
that amp is only 4 ohms, its not meant to handle those subs in dual 2 ohm the way that wiring diagram is set up.
setting them up like this:
should get you a 4 ohm load i believe.
someone please correct me if im wrong.
