IRN GYNT
- Warrenton, VA
Shot in the dark here as I know it's hard to diagnose problems from someone explaining a noise but I just wanted to see if anyone has experienced this or might know what it is before I haphazardly start trying to pinpoint.
My daughter's '98 2wd 4.0 auto is making a buzzing noise that's coming from either the transmission or lower/back engine. It happens in all gears (PNDR) and increases pitch as rpm increases. It's intermittent but happens more often then not.
Oil pressure is ok. Fluid levels are ok. Drivability/shifting is ok.
My first thought was either the oil pump (but pressure is fine) or transmission fluid pump.
