buying lockers...
ksmithers88
Jax, FL
as we all know, higher gears are numerically lower, and lower gears are numerically higher.
So when you're on the internet shopping and it says ox locker for d30 27 spline, 4.10 gears and LOWER....does it mean lower gears, or numerically lower gears
just curious...
just curious...
It mean Lower Gears (Numerically Higher), The reason is because the Dana 30 carrier comes in 2 different sizes,
An example is if you have a stock 3.55 ring gear you cannot fit the 4.10 without changing carriers.
the carrier break for a D30 is 3.73, which could be decieving if they said 4.10 and lower. I would think they mean numerically lower. Although you can buy "thick" gears that will work with the original carrier
