IndyXJ
Member #1314
- W.O.P.R. command
Checked out an 00 Limited today at a small lot. 105K miles, asking price is $5000 Full Time 4x4 and Part TIme, so I assume the 242 TC.
This will NOT be a wheeling vehicle.
Test drove it, acted as expected since I've had 2 before.
PROBLEMS--Rear wiper doesn't work(just fluid), NO AC output(important)--could be leak or just recharge?, Front speaker not working, some condensation dripping from the muffler which means it's just old and needs replaced, still normal noise output. Most troubling was the oil drops coming off the bellhousing. I saw a silver dollar size spot there before I test drove it. I drove it for a while, parked, didn't see any active drops after that.
If rear main seal, how much is this to fix IF I took it somewhere?
What would you offer as a bottom line on this?
The guy said it may be the oil sending unit, but I have no experience with fixing rear mains or oil sending units.
Thanks for any advice,
Bill
Bill
