Built MJ Axles (44/12 bolt)
XJfreakHO
Greensboro NC
Waggy 44, mounts are for a XJ/ZJ/TJ/MJ Currently under my Comanche
Bracketry is not the prettiest, but its all functional.
4.30 gears
Welded
Chromo Shafts and 760 joints with full circle clips (2 rides on em, perfect shape)
Isuzu 12 bolt, set up for Comanche, would need perches reset for XJ or set up for anything else.
Disc Brakes
4.30 gears
LSD
$850 for the pair.
Also have a set of steelies on the axles, 6 lugs, and 35 pro comp mt's with 40% or so.
Will let Axles, Wheels, and tires go for $1300
Lets make a deal.
Can take better pictures if requested, axles are still under the Jeep, and would need a day or two to get them out.
index.php
