Built axles from my XJ
COJeepin
Denver, CO
Both axles are from my XJ which handled up to 38" tires so long as not heavy on the skinny pedal.
1. Currie Ford 9" HP Front Axle
- Front Currie High Pinion shaved Ford 9" (Dana 44 knuckles/outers)
- 31 spline Moser shafts (passenger outer is a Chromoly)
- Yukon Super-Joints
- ARB locker
- Warn Premium locking hubs
- 4.88 gears
- Bolt pattern is 5 on 5.5
Will include the following spare parts:
- Chromoly inners and one outer shaft
- ARB mini air compressor (will easily drive front and rear lockers) with switches/wiring
- Set of new brake pads
- Steering ram and high steer arms from hydro assist
Axle is 64 3/4" (WMS to WMS).
I have $5500 in parts into this axle, asking $3000 for it.
2. Rear Ford 8.8 Axle
- 31 spline Mark Williams hi-torque shafts with c-clip eliminator
- Detroit locker
- 4.88 gears
- Superior diff guard
- Spare UNUSED built (with the bearings, retainer plate etc.) 8.8 Shafts from Super 88 kit
Axle is 64 3/4" (WMS to WMS) with a 1 5/8" wheel spacer (they are narrower than stock Jeep axles).
I have $3600 in parts into this, asking $1800 for it
Both axles are located in Longmont.
Can work out a deal if you want both.
