ChaseN
- Virginia/Iraq
Hi everyone
Just wanted to get some of the forum member's opinions on building up my XJ for towing. I'll be towing my 911 track car + trailer - race weight on the Porsche is 2750lbs, trailer is 1100, plus about 300 pounds of tools/rain tires/incidentals, for a total of around 4200lbs or so loaded (reaalllll close to the XJ's 5000lb rating). Tongue weight around 400 lbs (its hard to get much more since its a rear engine car. Don't know if this will be an issue or not, but I guess I could put the tires and tools up front if it needed more). The trailer is an open tandem axle with electric brakes. I know the XJ really isn't the ideal vehicle for this, but its what I got, and I'm NOT giving it up for a pickup (plus, a guy I race with tows his car behind a 6 cylinder 6-speed BMW wagon, so I figure the cherokee must at least be equal to that). I used to drive the car to the track, but some modifications this winter put it firmly into the NOT street legal category. I'll be towing it about 1-2 times a month during the spring/summer/fall (as far as 5-600 miles one way) and probably not at all during the winter.
I'll start off by telling you how my XJ is setup now -
-144k miles
-Around 20 psi of oil pressure at idle, 45+ at speed
-245/75/16 MTR's on Moab wheels (off a LJ Rubicon)
-2" budget boost up front
-2" OME HD lift springs in the rear
-RE monotube shocks
-Brand new 2 row radiator, water pump, 190* thermostat, fan clutch, serpentine belt, hoses (basically I went through the entire cooling system)
-Brand new headgasket (explains that ^
-Stock gears (I think 3.07s?)
-Cheesy class I hitch
-97+ intake manifold
I pulled an appx. 2100 lb trailer (without trailer brakes) back from Chicago to VA with this setup, with no problems whatsoever, except LOTS of downshifting in the PA and VA hill country.
Now for what I plan to do to the XJ -
-Centerforce dual friction clutch/pp. From what I understand, the clutch is the weak link that caused the massive difference in tow rating between AX15 and AW4 equipped XJs. I'd rather not burn a clutch up if I can avoid it.
http://www.centerforce.com/clutches.tpl?cart=12673321522841941&subsection=clutchselector&searchStr=csearchStr3&cstep1=step1&cstep2=step2&cstep3=step3&carmake=JEEP&carmodel=CJ%2C%20DJ%2C%20TJ%20%26%20YJ%2C%20CHEROKEE%2C%20COMANCHE%2C%20DISPATCHER%2C%20SPORT%20WAGON%2C%20WAGONEER%2C%20WRANGLER&caryear=1992
-Air lift airbags. I HATE the look of a rig squatting in the rear. These claim to increase the level load capacity by 2000lbs.
http://www.suspensionconnection.com/cgi-bin/suscon/59507-cherokee-air-springs.html
-Vanco hydroboost kit. This claims to increase the pressure at the master cylinder by 2-3 times. Braking is GOOD with 4000lbs + behind you.
http://www.vancopbs.com/category_s/76.htm
-Grand Cherokee rear discs. Again, just a good idea.
-Real Class III hitch. Probably just go get one installed at U-Haul. Necessary for the trailer's weight.
-Weight distributing hitch. Pretty self evident.
http://www.amazon.com/Curt-Manufacturing-17300-Distribution-Trunnion/dp/B001EOV4II
-Tekonsha Prodigy brake controller
http://www.etrailer.com/p-90185/Tekonsha-PRODIGY-Brake-Controller---Proportional.html
-Re-gear. I'm thinking about going to 3.55s, maybe 3.73s. Opinions? I honestly don't feel my Jeep is lacking power as it is (even with the stock gears and 31's) and I'm afraid 3.73s might be a bit too much gear when I'm driving around without the trailer (which will be 90% of the time). I've got the factory Chrysler 8.25 (thankfully) so I think I'm good there.
-Redline MT90 tranny fluid. Keep the manual tranny good and lubed/cool.Supposedly safe for yellow metals as well.
http://www.redlineoil.com/product.aspx?pid=46&pcid=7
-Redline shockproof 75w140 gear oil. Again, keep her good and lubed/cool.
http://www.redlineoil.com/product.aspx?pid=43&pcid=8
-Unibody stiffeners. I'm looking at the TnT items. I figure the 18 year old unibody with nearly 150k on it can take all the reinforcing it can get.
http://tntcustoms.com/uni-bodystiffeners-2.aspx
-Some sort of free flowing exhaust. Not looking for extra power or sound really, rather I'm under the impression that uncorking this can help keep water temps down. I can also get rid of the cat as I live in a non-emissions area.
Sorry for the looooong post guys. Just want to get everyone's opinion on all the different modifications I'm about to do, as I'm about to sink a couple grand in, and want it to be done RIGHT. My #1 priority here is safety (well, mayyybe #2...#1 is keeping the XJ
), and want to make sure I'm thorough and have a good understanding of what I'm doing. Any and all opinions are welcome - good, bad, I'm crazy, sell the XJ and buy a Silverado, etc. Let me know what you all think!
Thanks
Chase
-144k miles
-RE monotube shocks
Thanks
Chase
