i tested the fuel pressure at 31 psi and when disengage the vaccum i get 39 psi. which is what it needs to be i believe correct me if im wrong. i tested the fuel injectors and i get 15-15.6 resistance the highest is in the front? i would assume this is because they get hotter in the front of the motor? i cleaned the throttle body was pretty black but all clean now, i pulled the air temp sensor and it was also gumed up so i replaced (23.00$) lifetime warr. so i don't believe i have a fuel problem. when i pull the plug wires it does not fade anyworse between each wire. the "misfire" is still there. im calling it a misfire because that is how it seems not because i know this. im not sure how to test the tps or the cps. if anyone knows or have any info at all pease pease chime in. this is holding me back from wheeling so please help. it is progressivly getting worse day to day, this has been going on four about 8 days. also i replaced the fuel filter about a month ago, plugs, wires, cap, rotor about 8K ago.
thanks
dan
