HUSKYnXJnWI
- wisconsin
so I read this whole thread, sorry for your troubles, glad you found your solution. Initially, I thought the same issues- but mine seem pretty unique. My RPMS spike and drop violently once "it begins" I couldn't ever replicate how abruptly it spikes by hitting the accelerator.
My 91,XJ,4.0 recently began- cutting out- surging back: drops to 200rpm then spikes to 1500rpm- on the road in drive at 55, in reverse, in park in neutral: once it has started it doesn't go away. If I accelerate- it will respond smoothly: So I got home by accelerating to 65mph- putting it in neutral and coasting till 50mph, (while coasting the rpms looped quickly and cyclical from 500-1800rpms).
However, it runs perfect or relatively perfect: from start up cold through operating temp- then without warning- it just starts bucking and gets progressively worse. If I let it sit 5 minutes, it will be fine upon restart. If I immediately restart-same problem.
So I can drive it to work- and it will run fine (4 miles). Just can't leave town
I checked TPS volts which seem fine (volts in range, and no indicated spikes or drops): I am thinking coil and O2- relation to heat... I'll check Fuel Pressure.
I would not think CPS, IAC, MAP, since it runs Great until it gets warmed up and driven- strangely I drove it at my house for 10 minutes with ac on to heat it up- even trying to exceed 200 degrees- ran fine at 5mph and in park with and without AC. didn't start looping/bucking till 2 miles down the road.
Thanks in advance for any insight. I have lurked here for about 10 years- I think this might be my first post.
