Brown Dog Motor Mounts For XJ and MJ
Brown Dog
Because your Cherokee or Comanche is NOT a Wrangler.
In 2009, at NAXJA events across the country, Brown Dog Offroad introduced high performance motor mounts specifically designed for the Cherokee and Comanche.
Prior to then, Cherokee and Comanche owners who wanted high-performance motor mounts had to modify a set of Wrangler motor mounts - slicing the bushings (and sometimes your thumb) or trying to grind the interfering lip from the bracket arm.
Here's the difference....
So if your Cherokee or Comanche motor mounts are sagging...and you want to secure your engine into its youthful position...consider Brown Dog motor mounts. We make them to fit. No slicing, grinding or swearing needed. We mean it.
10% NAXJA member discount on all products (subject to change).
  • When ordering online, enter the letters: NAXJA when checking out. (Be sure to click “Apply” to get your discount.)
  • Or call 877-401-3877 and tell us you’re a NAXJA member and want your NAXJA discount.
We appreciate your business. Thank you.
