- Billings MT/Rapid City SD
working on my axle and snapped off the tap in a blind hole. Broke off just under the surface. Tried working it out with a chisel and center punch but just managed to chip off the only high point and jacked up the punch and chisels. The took a grinder to it and tried to grind a slot in the top, worked sorta but only got a quarter of a turn before it cracked up.
Tried drilling it but yeah that doesn't work when the drill bit and steel are the same hardness.
I'm out of ideas except to try and weld a piece of tube or rod to the tap and then weld a nut to that and turn it out.
Any other suggestions? It's on the diff bolts if that makes any difference.
