Brake Drums for Ford 9" w/ 35 Spline Yukons
MontanaXJ
Montana
I have a 9" axle out of a 1976 Ford F150. I went with 35 spline Yukons shafts and am having a brake drum issue. The center hole in the drum is smaller than the flange on the shaft so they will not fit. I was told that there are different drums that I could get with the larger center. For those of you running a similiar setup, what would be the year and model of vehicle that will have brake drums to fit this application.
Thanks
Greg Moonan
got lathe?
id take it outta the drums
what is the difference in hole size?
