Braided Brake Lines for my 87 XJ's in the rear
xjintx
Eddy, TX
OK, I just FINALLY got my D44 back in after gears and lockers done again. I searched but did not get a sufficient answer. I discovered the rear brakeline was broke in the process. I had a braided line on the rear :( The line broke right at the fitting in the block (no idea what it's called) where the hardlines runs on the axle to each wheel.
Is this just a fiiting on the hose that can be removed with new line or do I need to replace it. It is real hard to tell.
Where can I buy if needed and what's a sponsor source for braided line to buy again? As always no support in Waco!
Thanks!
Just get a mid 90's dodge dakota rear line. Its plenty long. I am using one on my rig at 6" and still has some slack at full droop.
P.S.--I have just never really been a fan of braided lines for some reason.
THANKS a million!!!
Just installed the Dakota rear line. Fit and works great... added lenght and fittings look better too :)
