Trying to bleed the brakes after a WJ MC swap, and I have zero fluid at the calipers. I had fluid when I bled the MC at the lower end of the hardlines, but now I have nada at the wheels. I double flared the proportioning valve end of the lines. Any idea why I'm not getting fluid to the wheels?
Did you bleed the prop valve as well? If not do so, then gravity bleed to the calipers first then pressure bleed ... so just let the hose hang until fluid runs down then hook up to caliper and again wait for fluid with the bleeder cracked open. Make sure the MC does not run out of fluid or you'll need to bench it again.
There is a fair bit of volume in the lines and caliper, so might take a bit to run down.
Also how are your soft lines? New or old and crappy? Might be collapsed if old.
