jeepxj2007
- Michigan
I have an 00 xj that is having an odd electrical problem. When you turn the blinkers on..in either direction, they will blink a few times, and then stop blinking. but the turn signal lever will still be engaged....so where do I even begin to look? I haven't been able to figure out anything that makes it better or worse.....i didn't look at the fuse yet...i prb should...but i figured it wouldn't blink at all if that was blown...and this will do it different amounts usually b4 shutting off.
