Rattlesnake
- Wilmington, NC
1994 Country, all stock
My right turn signal is not working correctly. Here are the facts...
- When I turn it on, I get a solid right turn signal light on the dash and it does not blink
- With the headlights on, I get the same result as above, but the right turn signal light on my dash stays on
- Hazard lights work normally
- Left turn signal is working normally
I have replaced the right, front socket with an OEM part from a pick-n-pull. I have also replaced the right front and rear bulbs and checked the ground behind the spare tire corner panel. Issue persists.
Any ideas? Thanks in advance!
