All items are in Erie, PA. I'll drive about an hour from Erie. I'm also making a run to the Tappen Zee bridge area of NY in a week. Going out friday so if your along I86 or RT17 i could meet you then. open to offers on any item listed and will combine ship. I am looking for 8 lug wheels and 37s and a dana 300
Pre 97 XJ sound bar with factory speakers gray in color $30 pick up it be hard to ship
XJ tow hooks for use with the tow hook bracket. They should fit in a small flat rate box so $15 to your door.
Pair of shock stem eliminators. they will fit in a small flat rate box $20 to your door
9 inch long sway bar disconnects. $50 to your door or $60 combined with the stem eliminators as they can work to mount the disco on a sway bar.
Pair of 12 inch travel bilstiens. 32 inches extended 20 inches collapsed $50 plus shipping.
Have a set of 5 15x8 soft 8s with AtoZ fab DIY 32 bolt beadlocks. 4 have 33x13.5 pirbull rockers and 1 has a 33x13.5 TSL. The wheels have one run after the welding and are holding air well. the rigs will probably need to be repainted as some of the paint didn't stick well. The tires are all in good shape no plugs or patches. $1000 pick up only
