im going to change my motor mounts tomorrow..what is the best way to change them with a jack....i mean under the engine..where do i place the jack and how?? help,advices...thanks....
if you have TC drop then take it out before you start taking it apart. Jason's article @ jeepin.com is good but the wood concoction he has is a little decieving. When I put the wood on the oil pan I put it on a angle to catch as much of the pan as possible.
I just changed mine two weeks ago, and I have the TnT belly pan which has a 1''TC drop built into it.
I ddint unbolt it. Was actually only about a 5 hour job working easily, minus the fact that one of the studs on the frame side broke, and I had to find a welder to reweld it.
