Best place to find black steelies with good/other B/S
RockRod
Janesville Ca
Looking for a backspacing of 3" or 2.75" Etc.....
All the local shops and 4 Wheel Parts only have 4" or 3.75" Backspacing.
Where can I find black rims (15 x 8) with a different b/s????
What tires on what lift are you trying to run? This sounds like a weee bit much.
bgcntry72 said:
Also looking for bulk supplier of ball joints and bearings.
That is all.
Very clever. At first I thought you were hijacking his thread. :laugh:
Not recommending the kind of backspacing you're looking for, but if you gotta have it, try the circle track vendors; Bart, Bassett, Marsh, etc. Check Speedway Motors. I use to juggle 2", 3" & 4" BS wheels to tune the chassis on my car. These backspacings are common in racing, but keep in mind that the wheels are built to be light weight and expendable. They play the roll of impact fuse when you hit the wall. It's easier and cheaper to replace a wheel than A-arms and steering links. My AR-767 8"X15" wheels are ~26lbs, while the racing 8"X15"s are under 20lbs.
